Old 05-07-2010, 02:15 PM   #2
brabus
Hi
Originally Posted by mikefocke
are often caused by grounding problems. There are several TSBs on the subject and the shop should have those and know them before they go removing anything in the steering wheel. I'm not guessing your shop knows Porsches as these are well known problems...my 2 cars have been in the shop 4 times for them.
TSB = Technical Service Bulletin
Hi sir,
Thanks for your reply , Sorry but what do you mean by grounding problems ?
Do you think its something to do with the battery ?
I dun think its the ICE that cause this , because i've had the ICE install 2 weeks before the warning lamp lights up and everything is fine, and only after i change to a new battery for 1/2 a day , the warning lamps lights up .
Before they install the new battery , they had to cut off some of my wires attach to the batt cos is not long enough , and later extend the previous wire with some lose wire so that its long enough to reach the batt terminal .
I suspect this is where it trigger the warning lamp , anyway tks for pointing this out , at least now i felt more convince if its the grounding problem .
Hope you can tell me more about the grounding problems .
Best regards
brabus is offline   Reply With Quote
