Old 05-07-2010, 08:26 AM   #1
brabus
Horn and Tiptronic wont work
Hi ,
Got a airbag warning on my dash , so went down to my workshop to solve the problem , after they remove the airbag and check , now even my horn and tiptronic wont work , the guys at the workshop remove the Airbag and found out that one of the wire snap , they rejoin the wire after when they found a spare wire on the contact support .
Everything works fine , but the airbag warning lamp still lights up and after many attempts trying to reset it for me , it will come back in less than 5 min , Now they suspect one of the wire inside the contact support is causing this problem , but the problem now is they can't confrim if its the wire causing this , i dun wanna order a new contact support and the warning lamp still remains .
BTW , my mechanics has confrim there is nothing wrong with the seat belt and i've not remove anything from the door also the airbag is working fine, the only thing i've done to the car is upgrading the ICE and change to a bigger amper battery .
Can any kind souls please advise me on a better solution ?
Thanks in advance !
A link to the contact support for better idea
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=996-652-213-00-M100&catalog_description=Contact%20Support%20for%20Stee ring%20Wheel%20Air%20Bag%20NOTE%3A%20Only%20for%20 cars%20with%20M%32%34%39%20%28Tiptronic%29%2C%20Bo xster%2FBoxster%20S%20%28%31%39%39%37%2D%30%34%29% 20%20
brabus is offline   Reply With Quote
