Originally Posted by RandallNeighbour
Jay Senoff's is quite effective from what I read on this forum... kinda shiny at an angle, but it does block wind well and may be cheaper than buying the cheesy center one from Porsche. My factory one rattles like crazy!
I cured the rattle/vibration issue by cutting 2 one inch strips of double sided foam tape and putting one on the lower edge of each side of the windscreen between the screen and the top of the rollbar.
You need to compress the foam to get the latches to engage, but it is this tension and the vibration absorbing properties of the foam which is invisible, but eliminated any rattle or vibration. Try it!
Cheers!
