Old 05-02-2010, 06:18 PM   #13
schoir
Originally Posted by zeeflyboy
Just an update:
So I just have one question now - I seem to be getting a fair amount of condensation at the moment above the reservoir on the boot lid, is this indicative of a problem or just the system sorting itself out?
Cheers for any input and thanks for the advice you've already given guys!
Zeeflyboy:
Condensation under the trunk lid, directly above the coolant tank, is sometimes an indication that the O-rings inside the pressure relief valve, or one of the rubber membranes inside are failing or have failed.
You can just replace the O-rings or the complete pressure relief and both are easy DIY's.
Regards, Maurice.
schoir is offline   Reply With Quote
