					Originally Posted by suburban99
				 1997 Boxster light in defrost switch is on...thought it might be the relay so I replaced it. Still on. Goes off after car is locked for 30 minutes or so. I assume that when you push the defrost button the relay is supposed to stay energized for 15 minutes or so and then turn itself off. As I have no rear defrost I assume that it's for the heated mirrors...Or am I wrong? |
You do have rear defrost because all Boxsters came with rear defrost standard.  This was done to accommodate the rear defrosters on the hardtops, which were an option from the introduction of the Boxsters.
If you look at the area where the driver's side roll bar meets the rear convertible top well, you will see the plug provided for the rear defroster.
Regards, Maurice.
