Does it go part way in then stop? There are two parts to the ignition. There is a tumbler section and then the switch section. When you put the key into goes through the tumblers and presses the switch in the back down. If it doesn't go in at all then it's a tumbler section problem and you'll probably need dealership or locksmith help. If it goes almost all the way in then jams it maybe a switch problem and that's a DIY fix.
