You experience no vibration at all while at speed? If it's the front mount you will notice it coming off throttle on down hill sections, it will feel like a momentary buck. IMO, if it is the mount it would be problematic under way as well. It could be one of the two rear mounts, I would make sure it's not in the engine itself, I would also call back to the dealer who sold it and tell them what you're experiencing in case they were under it and have some clue as to the problem, good luck 1200 is a lot but I'll bet you'll be fine.
