Originally Posted by Reborn996
Do the 2000 Boxster S models also have this plug? I could not find one...
ALL Boxsters came with this plug from the factory. It was put in because the hardtops (with defroster) were an option from the very first model year.
Here is where it is located, directly over your left shoulder as you sit in the driver's seat:
Sometimes it's oriented 180 degrees around.
You just flip up the little plastic cover by pulling up on the little tab, exposing the connector for the defroster wire:
Regards, Maurice.
