I've contemplated this also....
as its one area of my car that has seen its share of rocks, etc....I have a bunch of chipped up spots all over the front bumper....From a distance you don't even know their there, but up close you can really see them.....Probably a good sanding, priming and repainting would make it look like new...
Your bumper is actually cracked thru? That might require a new one, but don't quote me.....I've seen front ends in the 800-1000 range if I'm not mistaken, and most of those were unpainted....Hopefully someone whos done this chimes in....I know LA Dismantlers usually carries these.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
