Originally Posted by chaudanova
What optimal tire pressures are you guys running with the HTRZ-III?
I've experimented with standard 29F/36R, 30F/36R, 31F/32F/33F/34F&36R setups... Not entirely sure which I like best yet, but it's quite variable for me, since I've been experimenting with different front and rear damper stiffness settings as well.
The 987 has 30/37 as standard pressures. I found 28/36 gave the best wear on the PS2s, so I've set up the new Sumis the same. So far, I have no discernable wear, so as I put more miles on them I should be able to see.
These are cruising pressures.
