Old 03-01-2010, 04:27 PM   #1
Quickurt
Quickurt's Avatar
Originally Posted by eightsandaces
Take my advise, soak the bolts till your sick of crawling under and then keep doing it anyway. I was 10/12 breaking the same two on each side, which leads me to believe they are the hottest. These bolts seemed extra wimpy, then again steel & aluminum is always tough. Tomorrow should be fun, web tutorials, easy out extractors, faith and luck.. If anyone considers them self the sultan of extraction, I'd love to have your input..
If they broke with heads on them, what makes you think an easy out is going to get them out? The best luck we had in machine shops is left hand drill bits. Most industrial supply houses will stock them. Be EXTREMELY careful center punching the bolts before drilling. Some poeple have had good luck using soldering guns to heat the bolt after drilling it. If you get it good and hot and then let it cool, it will crush itself inside the more solid metal, if you get the walls of the bolt drilled out thin enough.
Good luck.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
