Old 02-16-2010, 05:56 AM   #2
Bladecutter
Originally Posted by 23109VC
I'll try cleaning it and see if that works. if not, i will look into replacing it... hopefully a cleaning will solve my problem. I have 78k miles on the car. I don't have a K&N filer or anythign like that, my airbox/filter are all OEM.
if my maf is bad and/or dirty - will clenaing it and/or repalcing it make any diffference in performance/driveability?
It truly does depend on the reason why the MAF is setting off the trouble code.
If its exactly the same issue as my car had, then cleaning the MAF won't have any effect, as the sensor was below range, and not responding to engine speed changes.
If its out of range, but is changing, then cleaning the MAF might be the answer.
Or it can be a truly different cause setting off the same code.
No one can know until the computer is hooked up, and the sensors are read.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
