Old 02-08-2010, 11:18 AM   #10
schoir
Originally Posted by loxleyboxter
Thanks again , very helpful. Does anyone think that because the car has been outside for 8 weeks in freezing conditions, covered in snow and ice, that the seals on the Hardtop could have maybe shrunk and let water in ?
The hardtop has never leaked before when it has rained in summer, and i did see some water around the centre roof latch during the cold weather.But could a tiny drip cause SO much saturation to the carpets ??especially under the R/H Seat.
Is there a product available to apply to the hardtop seals prior to fitting for the winter that provides a waterproof seal ?
I have to check the drains first, but if these are clear then it has to be the Hardtop seals . yes ??
No! As was quoted below, there is also the possibility that water is getting in past the rubber membrane under the door panel. This is especially true if the membrane was not properly adhered to the inner metal door skin when, for example, a window regulator was replaced.
You can check this without removing the door panel by monitoring whether any moisture is building up on the lowest horizontal portion of the door panel and/or on the carpet on the inner part of the door sill.
Regards, Maurice.
schoir is offline   Reply With Quote
