Old 01-31-2010, 07:50 AM   #2
tholyoak
You will need the switch cluster with the cruise stalk and the cruise control unit itself, also you will need the pedal switch. The control unit attaches to the gas pedal with a cable, that and the wiring from the switch to the control unit and the control unit to the car ( cluster, brake/clutch switch and OBD port) . The parts are fairly expensive new, ~$150 for the stalk cluster and ~$1000 for the control unit. I have a good control unit removed from my car when I did the engine swap that works just fine. If you are interested in it just send me and email or message through the board. I would sell it very cheap.
-Todd
Originally Posted by Mark_T
I've got a '99 986 5-speed and I'd like to fit it with cruise control. My preference would be to retro-fit it with the original Porsche system. I'd probably have to have that done at a dealer and I'm wondering if anyone has done this and has an idea of the cost. The other option would be some aftermarket unit but I haven't had much luck finding anything. Suggestions?
Thanks,
Mark
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
