Originally Posted by mebiuspower
How about they're kryptonite to everything?
Run flats shouldn't be on any car except Hummers/Humvees, and the Batmobile.
LOL! Well run flats are definitely out not that I was really considering them in the first place as I thought there would be a problem but wanted to be sure.
I am looking at Bridgestone Potenza RE050A Pole position in Front, either 205/50 YR 17 or 225/45 ZR 17 and Rear 255/40YR 17. Nowhere in tire rack is any mention of run flat on these tires so I guess I am OK. When I do call to order I will be sure to axe about the run flat to assure they won't be that type. According to the reviews at Tire Rack these are right up there with MichelinPS2 tires.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
