Old 01-02-2010, 09:13 PM   #10
Paul
Porsche "Purist"
Paul's Avatar
Originally Posted by Bladecutter
If you want the best possible idea, then here's my suggestion:
Buy another set of 17" front wheels, and place them on the rear of the car (Yes, it will work just fine). Then install 225/45-17 tires on all 4 wheels, using a tire that has an asymmetrical tread pattern. This will allow you to rotate the tires front to rear, and side to side anytime you want.
Using the same size wheels and tires all around won't compromise the driving performance, because you don't use any of it, and you will no longer have any issues with the rear tires wearing out as fast.
Congrats, now you can drive the way that you want.
BC.
Agreed but be aware of oversteer, especially if you put the same pressure in all 4.
1987 924S. 2002 996TT. PST-2
