Old 01-02-2010, 07:14 AM   #12
renzop
If you want long tire life get harder tires. A nice cheap all-season passenger tire should do it for you. Of course the handling performance will stink so why bother?
Other than ruining the performance with a crummy tire, you can try two other things:
1) Get an alignment - 0 degress front camber, 0 degrees front toe, as little camber as you can get in the rear (it will be a negative number - get it close to 0), 0 degrees rear toe
2) DRive like a granny. Accelerate slowly out of turns. Turn in slowly and gradually. No full throttle.
Basically, if you want to save money on tires you bought the wrong car.
renzop is offline   Reply With Quote
