Stock speakers are 0.75" tweater and 4" midrange (if you have the sound pack), or a plain 4" all rounder on its own. Thy are poor Nokia made paper units.
Easiest replacement is from MB Quart - they do a similar set up with polycarb cones for about $60.
After that, nmost units are 1" tweater which will fit but you need a bit of work with a Dremel. You need to use hot melt glue or epoxy to mount anything beyond the MBQs to the stock grille, or make your own mounting plate with mdf using the stock grille as a template.
