So I began the engine removal process. Things I have finihed so far:
Rear bumper cover removed
exhaust removed
sway bar removed along with the other supports in the area
drained oil
drained three anti-freeze hoses
disconnected battery
I was looking around for the fuel lines and cant seem to find the connection points. I also need to figure out how to disconnect the linkages to the trans.Long way to go. Any ideas or information would be greatly appreciated.
I would like to take the whole drive line out together since I will be replacing the clutch. Do you see any issues with that?
