Thats a single row IMS bearing in your engine.. based on the deeply set IMS flange.
While it was apart you should have at least removed the seal from the factory bearing while you were in there.. It only takes 20 minutes to do.
That dent on the axle cover won't create a noise unless the cage/ balls of the CV joint contact it... I bet the sound was a torn engine mount.
