Thread: windstop
Old 06-01-2005, 09:56 AM   #3
larez2
You don't need to drill. The holes are already there, beneath the roll bar padding. The roll bar padding can be removed by hand, but you have to pull very hard.
You will also need a rivet gun, to put the rivets in, or some small screws would probably do the trick also.
The hardest part is removing the roll bar padding - the 2 hoops and the center piece. It's on there tight. Be careful not to loose the little plastic things that hold the roll bar padding in place.
The dealer wants $190 for the labor to do the install. I asked. Ridiculous if you ask me.
Good Luck,
Larez2
larez2 is offline   Reply With Quote
