Ok so the plugs look good. I do think I found the problem and PK is right nothing to do with the oil overfill.
The car will start maybe once out of a dozen times. The times that it does not start, it cranks without engaging the clutch pedal. If it does start, when you turn the key it will not crank the engine without the clutch.
Question: Is it the clutch switch of the ignition switch that is messed up?
