Originally Posted by blinkwatt
oh boy.....now you guys are mixing stuff up.....The IMS failures that cause engines to blow are different then when the RMS & IMS leak....It's a leak,not a big deal. IT HAS NOTHING TO DO WITH WHAT YOU READ ABOUT ALL THESE ENGINES BLOWING....
So an IMS leak has absolutely nothing to do with an IMS failure?
Oil leakage at the IMS can be from the flange bolts, but why couldn't it be because the bearing seal has failed? Which would be a disaster waiting to happen.
