			whati would do is put the top down put up windows. then with ur finger push the switch. start the car and see if it does it. if it still messes up then you know the problem is somewhere from the switch on to whereever it is wired to. if you do it a couple of times and it has no problems it could be ur latch. just a thought. then at least you can rule that out
