Old 10-14-2009, 09:32 PM   #1
schoir
Originally Posted by BoxsterLewis
80% of the time when someone gets of out the passenger seat the window doesn't go up or down under the convertible automatically like the drivers side does and it sounds bad! I have to put it down and up manually. Anyone know the cause of this?!
Lewis:
If it behaves the same way whether you pull on the inner door handle or on the outer door handle, it's most likely NOT any one of the three microswitches. I would first suspect the window regulator itself (and very, very rarely the window motor).
Straightforward DIY, with the hardest part being the removal of the door panel. After you have removed the door panel a couple of times, it's a piece of cake.
Regards, Maurice.
schoir is offline   Reply With Quote
