Originally Posted by Topless
Check wheel bearings. If the front motor mount has not been changed it is toast.
Thanks fitted with 17 inch wheels (standard) Front motor mount has not been changed by me. Only noticed it so far on left hand turns.Wheel bearing/Drive shaft could be was thinking that.Only had it about 12months 20km will check wheel bearings and engine mounts thanks for the tips.
