Old 09-22-2009, 05:05 AM   #14
ltaudio
replaced the AOS and upon re-firing the smoke machine re emerged, it idled rather well and so I gave the throttle a few light taps and eventually the smoke died out. I checked the levels and they are all fine the only issue is there is a slight hiss sound, much like a vac leak. When I remove the oil filler cap the motor starts idling funny, rises falls and sputters very sporadically. Started it up again this morning, small cloud of smoke and stopped almost instantly. Figure its remaining oil in the intake, working its way down to the motor. Should there be an issue when I remove the oil fill cap while running.
ltaudio is offline   Reply With Quote
