Old 09-20-2009, 08:31 PM   #2
jhandy
You will have a balance problem that may cause harmonic resonance failure of the crank. You will have chatter unless you by an certain clutch ( sprung or unsprung) I dont remember. You will have trouble resurfaceing the after market wheel, if they dont make your inserts anymore. Look up flywheel and jake raby in the search. Do the underdrive pulley- 200$ and 10 HP. less rotating mass.
2002 S
jhandy is offline   Reply With Quote
