Old 09-20-2009, 05:11 PM   #3
Dar01
Originally Posted by CJ_Boxster
theres an evap valve under the left side intake plenum. give it afew good smacks with a wrench or screw driver and it should start working... for a little while.
Thanks for the reply CJ.....was yours stuck open or closed?.....I am still getting a p0455 code (large leak)......replaced the valve up by the canister, and the shutoff valve (on the filler neck)...plus the gas cap....this is killing me.
Did you replace yours?......the end of the valve at the back of the car is just a clamp, but how does it disconnect at the other end (towards drivers seat)?
Thanks for your help.
I thought you got rid of your Boxster??????
Dar01 is offline   Reply With Quote
