Old 06-30-2009, 12:35 PM   #12
bmussatti
Guest
Posts: n/a
Originally Posted by RandallNeighbour
That explains a lot. Bill, the 987's no longer have a real temp gauge. It will rise to the right spot before the motor is truly up to temp and only climb when the computer says it should so you will pull over and get the motor looked at. It's now like the crappy ones found in American cars. If the car's not overheating, that needle in your 987 will not show any fluctuation at all.
Mark and I have checked this out on his 987 at the track when he's been absolutely brutal to the motor on the track and that needle should have moved a little and it does not move past the operating temp reading it is programmed to display.
The 986's have a temp gauge that moves around when you drive the car, hence all the guys freaking out because they've never owned a car with a fully operational temp gauge before.
Randall, how is Mark doing?
My needle moves for sure, just not much once the engine warms up. And the engine bay fan will cycle on or off as needed, as does the multi speed fans up front.
I am surprised dealerships don't recommend this service to pry an extra $1,000 out of our pockets at say a 60K service.
