Old 05-05-2009, 09:51 PM   #10
schoir
Originally Posted by rick3000
Well, I have the old parts. I am interested to see what parts need to be replaced. I found this on RennTech, but it sounds fairly complicated.
I am hoping it ends up being as simple as replacing the motor with the new one, and putting in the new style relay.
Rick:
BTW, if you wanted to stick with your old style transmissions (which is not what I have chosen to do), I don't see why you wouldn't be able to swap in the new '03-'04 glass top and frame in place of your '99 top and frame and have it work the same way that the old top worked.
I don't believe that the change from 3 bow to 4 bow frame would have any negative effect on the timing providied by the after-running time built into the "old" system.
It's worth a try if your old "Version A" transmissions and the rest of your system are working 100%. It's easy enough to put the old top and frame back on if it doesn't work for you, at least until you get the rest of the new parts.
Regards, Maurice.
schoir is offline   Reply With Quote
