I believe the red-line on 2.5L's is 6,800rpm. As mentioned earlier, the cam switch is at about 5,000 rpm so far maximum accleration you would want to stay in between these two parameters. If you are just cruising on the highway just stick it in 5th unless you need to downshift to pass or something.
