Old 02-27-2009, 01:30 PM   #3
mb911
Originally Posted by achillian
What kind of input are you looking for? Are you concerned about appearance or function? That design looks very similar to a Stebro brand exhaust. It will be extremely loud, especially just before 3,000 rpm. For appearance, I think it looks a little weird the way the pipes are welded together, but I guess you really won't see that once it is mounted on the car. Make sure those welds holding the pipes together is very strong, because if they are not, the exhaust will begin to rattle over time. You might want to add a set of thicker tips to make it look sharp once mounted. Reference the Fabspeed website to view some different tip styles. On a positive note you should get some great weight savings over the OEM muffler!
any and all. I have heard boxsters with no mufflers before and I though of them as fairly quiet. The weight savings is huge. this setup weighs approx 10lbs and is 321 stainless. This is only tacked as I waitng on the car to do final fittment
mb911 is offline   Reply With Quote
