I am still waiting for parts from porsche. I am going to move forward and do what I can with out these parts. I took a picture of my flywheel. This is the flywheel out of my boxster. I just had it changed along with my clutch before I pulled the motor. I am no longer using the stock clutch but I will be using my stock flywheel. I took it out today and didn't realize that it had accumlated quite a bit of rust. Check out the photo below.
Before Photo.
I was pretty sure that I was going to have to buy a new one.
I went out to my local hardware store and bought some #2 and #00 steel wool and some WD40. I started with the #2 and finished off with the #00. I think the results were great.
Let me know what you think. Do you think I need a new flywheel? Also does anyone know if I need new flywheel bolts? Do they stretch? Correct me if I am wrong, 90ftlbs tourque on the crank bolts and 25 ftlbs on the pressure plate bolts.
After Photo.
