Old 02-12-2009, 05:52 AM   #2
bmx672
I didn't take any pics... yet... but we (my brother-in-law) had some very innovative ways to mount the dash speakers. Since the mounting brackets were molded to the old speaker we didn't have a lot of choices as far as using leftovers. And the tabs on the new Infiniti's were really long. Our solution... We heated a utility knife blade with my torch and melted 2 slits 1/4 down from the edge of the empty housing. That gave us enough room to insert the new speaker/tabs through the housing, by gently rotating it and inserting the tabs. We then bent another tab and screwed it into the side of the housing. the last tab we lined up with one of the original mounting screws that goes into the dash. It worked perfect and we didn't have to mess around with any special mounting hardware!!!
The first door took a while... the second took 1/10th the time since I knew what I was doing. I routed all of the wires for the sub through the firewall seal on the left of the battery that houses other wires. We heated a screw driver and melted our way though... we needed more room than just making a small slit.
Anyway, next is the iPod hook up. That will be easy compared to this.
bmx672 is offline   Reply With Quote
