...for your take on that mod. If you will indulge me another question, since the cylinders are cast into the block, how do you remove the old ones and replace with new ones? Seems like you would have to re-cast the block around the new Niki's? Not wanting to be a pain in the ass, but I am fascinated with what you are doing and if my mill goes grenade you most likely will have a customer on your hands. You must have a way of removing the damaged cylinders etc. if you can re use the case. Old age wants to know...
AKL
