alignments on this car are VERY easy. any shop with the new hunter machine should be able to do it fine in about an hour.
there are allowable 'ranges' the machine gives you for an 'in spec' alignment. within these ranges, there are good alignments and bad alignments. if you give the shop the numbers to hit, they should be able to do just fine even if they've never touched a boxster before.
