i just messed with it some more, and i finally got it out of gear. i had to go underneath, and pull the front-back lever (lever on the tranny that the cable attaches to), while also pulling on the side-side lever; and the tranny popped out of gear and will now go into neutral. i can now move the shifter to all gears except 5th & 6th. also, when i start the car, and put it in 1st gear it gets stuck again (atleast i know the trick to put it back in neutral). i'm still not sure if it's a cable or tranny issue though...any ideas???
