Old 10-02-2008, 11:28 AM   #33
Quickurt
Quickurt's Avatar
Originally Posted by larryshomework
QK - I live in Birmingham so I drive 25 frequently. There's a great section just south of Leeds well before you go up over the mountain. The hairpin on the top of the mountain is pretty fun and the flats south of the mountain are not bad either.
I don't know if you stopped at 29 Dreams but it's a motorcycle resort at the bottom of the mountain on the south side. Interesting place and worth a drop in if you're cruising through.
To keep this on topic, there are some great tips here. I did the BMW one day M-school and learned quite a bit in one day. Amazing how much more there is to learn. The looking ahead thing is one of the most valuable things I learned - that and proper braking. Now if I could get the heel/toe thing down...
The heel/toe thing is VERY dependent on your pedal set up. The Box pedals seem perfect for either method, depending on the size of your feet. Smaller feet are usually attached to smaller legs, so, use the ball of your foot on the brake, pivot your leg to put your heel on the throttle and practice the amount of throttle needed to bring the rpm up to make downshifts silky smooth. You should be able to release the clutch as fast as you do upshifting without jerking the car around because of miss-matched engine speed.
For those with feet the size of mine (they go with my bear paw hands, but I didn't get the matching pleasure that sometimes accompanies these two ) use the ball of your foot on the brake pedal and the right side of the bottom of your "wide foot" on the throttle.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
