1. Debris in the blower cage (possibly foam insulation), or blower motor bearing whine. Most likely the latter since it stops in time. In the first case, disassmbly and cleaning. In the 2nd, blower motor replacement.
2. Check that hinges are tight and aligned properly. Look for even gaps around the door. Not likely the latch, but if so, probably due to door misalignment.
