Old 09-11-2008, 09:47 AM   #4
insite
Summary (Fronts Only!!)
the dampers curves are reasonably close to what i've calculated are the 'correct' values for this car with my chosen spring rate of 400lb/in. the minimum setting is underdamped and the max setting is overdamped; this is good, it means that the 'middle' of the curve is where we want to be.
by my calculations, for these springs, setting my front dampers between 18 - 24 should be about as close as i can get to my ideal.
look for a similar analysis of the rears shortly.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
