Old 09-01-2008, 10:36 AM   #11
Brad Roberts
Brad Roberts's Avatar
Slide the new AOS back down into the same hole you removed the other one from smile.gif I like to place a little oil on the rubber O-ring that goes into the block, and place a little oil on the bellows that slips down onto the steel tube protruding from the block. Make sure you watch the O-ring go into the block!!
This is the AOS installed with the new hose clamp. MUCH MUCH easier with the clamp. I preset the clamp so it *just* moves around the bellows. This allows me to "locate" it for easy access of the 7mm nut driver. You can also see I put the bracket back for the O2 sensor! AFTER tightening the new clamp for the bellows.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
