checked pins
I checked the seven pins and they are clean and straight. I'll go back and check the socket for movement and the check the fuses. I didn't realize the fuses were separate in function. However, would a blown fuse effect the driver side headlight and not the passenger side headlight? Passenger side works Ok.
ElStevano
99 Boxster Ocean Blue Metallic
