Originally Posted by Bob O
Left to do: Change the fuel filter. My floor jack won't get high enough to allow jack stands high enough to let me under the car to get at it.
0
Bob, I've got several pieces of 2X4 wood cut to about 8" in length. My car is so low that I have to drive each end up onto these 2X4's to get it high enough to get the jack under it. Once I've got it on jack stands I can raise it up higher by simply placing one of these 2X4 pieces on top of the jack pad and use that to then jack up the car (the 2X4 is sandwiched between the jack pad and the car). It should give you the extra lift you need to get the jack stands up higher so that you can fit under the car.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
