Old 08-06-2008, 10:41 AM   #10
insite
okay, i went out and looked. in the picture below, 'B' will be inboard. you'll want to move the pillow ball to position 'A'.
on another note, i did a little more research into helper / tender springs. first of all, i had the nomenclature wrong. TENDER springs are softer springs that help w/ bumps. HELPER springs keep the main springs seated when the suspension is fully extended. without them, at certain ride heights the main springs might come unseated and make noise.
anyway, TENDER springs are what will improve the ride quality. both Eibach and Hyperco make some that are commercially available. they are 3" in length, so we MIGHT need shorter main springs. i will no more when i actually have my KSports sitting in my lap. TENDER springs can be ordered in various spring rates, usually from about 150lb to 400lb.
i will likely install my KSports with the factory provided tender springs and see how the ride is before i make a decision on tenders.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
