Originally Posted by RandallNeighbour
Insite, I just bought the same set from the same people on eBay! What a small world.
I did not request the special spring rates, so what do I do now?
if you just ordered them, you can probably call TCS and have them change the rates. in my opinion, their standard split of 5.3/9.0 (300/500) is WAY too rear biased. you usually use your car on the street, right? i'd go 5.3/7.0 (300/400). it's not possible to go lower than 7.0 in back without having them re-valve the dampers. if you can't get them to change the rates before they arrive, you can buy a set of 7.0 springs from KSport for under a hundred bucks.
