Old 07-30-2008, 04:18 AM   #11
insite
Originally Posted by j.fro
Hey, how were you able to adjust the ride height independent of the spring perch?
below the spring perch where the coilover is inserted into the wheel knuckles, there is a locking collar (on the front wheels, there is a locking collar on the very bottom of the strut, too). loosen the locking collars. then, twist the WHOLE strut. it will thread in and out of the wheel knuckle, making the entire strut shorter or longer. finally, tighten the locking collars. they need to be TIGHT; use a flathead screwdriver and a hammer to do this. BTW, if your struts make a knocking sound, these locking collars are loose.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
