Old 07-29-2008, 10:46 PM   #2
fragdude
this isn't really a long term fix, but if you need to put gas in your car there is a manual unlock in the fender where the passenger door meets it. Its accessible when you open the passenger door and is on level with the filler door, its like a ring that you pull out.
Maybe you already knew that though...
Good luck with you problem, maybe its a bad security system computer thingy under the drivers side seat ?
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
