Old 06-11-2008, 12:35 PM   #1
insite
you have to lower the motor about 2". remove the mount to engine bolts (some won't come all the way out; they're too long). then, remove the mount to chassis bolts. lower the engine 2". then, facing the back of the car, rotate the mount couter-clockwise. some of the bolt holes on the mount to engine interface are actually slots designed to allow removal w/ some of the bolts still more or less in the motor. once you get it out, it will be very obvious to you how it works.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
