Old 06-08-2008, 11:17 AM   #10
heyjae
Originally Posted by Sputter
I bought one from Napa for my 02 S.
The size is 13/16" x 83-3/4" or 20mm x 2127mm.
edited in it's a Gates belt. One thing comes to mind that you may have non air belt? It's something like 5 inches shorter.
Are you trying to slip the belt over one of the pulleys? If so, try sliding it over one of the idler pulleys (the pulleys without the ridges). I found sliding it under the one on the top left next to the alternator the easiest. I'm using a shorter Goodyear belt since installing an underdrive pulley.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
